HOP 5: Moscow (55.8 N, 45.6 E) [SOLVED!]
Damn Right ! :smiley:
The knight is white and it should be on H8.
just wondering how the pawn can make its way to H8 without placing a check to the King on G8?
Presumably the king moved out of the way (either the rook shifted, and the king took its place, or the king came all the way out into the centre) and then moved back after the promotion :)
haha, that would be a nice trick by the black :smile:
